Using simple to get and modify parts, build and construct a Nerf gun that is capable of shooting a Nerf dart hundreds of feet.
cut the end off the water hose wand with a hacksaw
drill a 1/4 hole on the back of the endcap and glue in the valve from a inner-tube.
standard PVC glue to put everything together.
There definitely is a limit to nerf darts. I found that as I get to about 100psi, the nerf darts tops start pop-ing off, or blows a hole out the side of the dart. Perhaps the next phase is to make some low cost darts that can wistand the pressure.
hehe, I tried to use some .22 cal ramset rounds to fire nerf darts but they just vaporised :/ They did look prety spectacular.
