See a gif of the Firefly Jar here.
See a video of the Firefly Jar in action here.
Solar rechargeable mason jar lid for pretty flickering lights
Is there a schematic for this project ! .
cheers
spike
Just wondering if you found that the caps were necessary after not using them and if so was the value intended .1 or 1 uf. Thanks.
Great project!
Small question: how did you connect the solar cell to the PCB? There's no pin, just solder pads.
Thanks!
why do you have two DPDT switches in the schematic? Am I missing something?
the schematic component has two parts. one switch connects/disconnects solar cell to batteries and batteries to MOSFET.
looks great! can I ask, why did you not populate the capacitors on your board?
Hey,
nice project. Where do you get those jars and these lids? They aren't this common here in Europe.
Ball Canning Regular Mouth Half Pint Canning Jar 8 oz. 12-Count https://www.amazon.com/dp/B00HNPNNLS/ref=cm_sw_r_cp_awd_O1CKwbDJK4TSB
Hmmm... i was interested in building this. Is the schematic no longer available? Thanks.
