1Step 1
Connect any GND pin to an empty minus-Rail on your breadboard
I prefer to use pin 39 on my RPi2B to have more structure
2Step 2
Connect your LEDs
- Red LED with a 220Ω-resistor on Pin15 (use a red m-f-wire), connect to GND-to-minus-Rail
- Yellow LED with a 220Ω-resistor on Pin13 (use a yellow m-f-wire), connect to GND-to-minus-Rail
- Green LED with a 220Ω-resistor on Pin11 (use a green m-f-wire), connect to GND-to-minus-Rail
3Step 3
Connect your Button
- Use a white m-f-wire and connect one side of the button to Pin8 on your Pi
- Connect the other side with a black m-m-jumper to the GND-to-minus-Rail
