After a few days of frantic code writing, I managed to cobble together a functional set of programs to send and receive the four coordinates of each box, the number of boxes detected simultaneously and the current box number …. All in a user friendly format that can later be processed into commands to steer the WEEDINATOR machine.
Here's the code used on the Jetson TX2:
int i2cwrite(int writeValue)
int toReturn = i2c_smbus_write_byte(kI2CFileDescriptor, writeValue);
if (toReturn < 0)
printf(" ************ Write error ************* \n") ;
toReturn = -1 ;
return toReturn ;
void OpenI2C()
int length;
unsigned char buffer[60] = {0};
//----- OPEN THE I2C BUS -----
char *filename = (char*)"/dev/i2c-1";
if ((kI2CFileDescriptor = open(filename, O_RDWR)) < 0)
//ERROR HANDLING: you can check errno to see what went wrong
printf("*************** Failed to open the i2c bus ******************\n");
//return;
if( ioctl( kI2CFileDescriptor, I2C_SLAVE, PADDYADDRESS ) < 0 )
fprintf( stderr, "Failed to set slave address: %m\n" );
//return 2;
void I2CDataHandler()
printf(" My box number = %i \n",myBoxNumber);
for( int j=0; j < 4; j++ )
if(j==0){i2cwrite(200+myNumberOfBoxes); } // Total number of bounding boxes.
if(j==0){i2cwrite(140+myBoxNumber); } // Designates bounding box number.
i2cwrite(120+j); // Designates box corner number
printf(" intBB[j] = %i \n",intBB[j]);
top = intBB[j];
myArray[j][0] = static_cast<int>(top/1000);
printf(" myArray[j][0] = %i \n",myArray[j][0]);
i2cwrite(myArray[j][0]);
top = (top - myArray[j][0]*1000);
myArray[j][1] = static_cast<int>(top/100);
printf(" myArray[j][1] = %i \n",myArray[j][1]);
i2cwrite(myArray[j][1]);
top = (top - myArray[j][1]*100);
myArray[j][2] = static_cast<int>(top/10);
printf(" myArray[j][2] = %i \n",myArray[j][2]);
i2cwrite(myArray[j][2]);
top = (top - myArray[j][2]*10);
myArray[j][3] = static_cast<int>(top);
printf(" myArray[j][3] = %i \n",myArray[j][3]);
i2cwrite(myArray[j][3]);
And the code for recieving the data on an Arduino:
#include <Wire.h>
long y[4][4];
int a;
int b;
int c;
int d;
long x =0;
int i;
int j;
int numberOfBoxes;
int xMax;
void setup()
Wire.begin(0x70); // join i2c bus with address
Wire.onReceive(receiveEvent); // register event
//Wire.begin(0x50); // join i2c bus with address
//Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
void loop()
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
//delay(50);
int x = Wire.read(); // receive byte as an integer
//Serial.print(" Integer: ");Serial.println(x); // print the integer
if(x>199)
numberOfBoxes = x-200;
if((x>139)&&(x<200))
j=x-140;Serial.print("Number of boxes: ");Serial.print(numberOfBoxes);Serial.print(", Box number: ");Serial.println(j);
if(x==120){ i =-1; }
if(i==0){ y[0][0] = x*1000; }
if(i==1){ y[0][1] = x*100; }
if(i==2){ y[0][2] = x*10; }
if(i==3){ y[0][3] = x;}
a= y[0][0]+y[0][1]+y[0][2]+y[0][3];
if(x==121){ i = 4; Serial.print(" corner a: ");Serial.println(a);}
if(i==5){ y[1][0] = x*1000; }
if(i==6){ y[1][1] = x*100; }
if(i==7){ y[1][2] = x*10; }
if(i==8){ y[1][3] = x; }
b = y[1][0]+y[1][1]+y[1][2]+y[1][3];
if(x==122){ i = 9; Serial.print(" corner b: ");Serial.println(b);}
if(i==10){ y[2][0] = x*1000; }
if(i==11){ y[2][1] = x*100; }
if(i==12){ y[2][2] = x*10; }
if(i==13){ y[2][3] = x; }
c= y[2][0]+y[2][1]+y[2][2]+y[2][3];
if(x==123){ i = 14; Serial.print(" corner c: ");Serial.println(c);}
if(i==15){ y[3][0] = x*1000; }
if(i==16){ y[3][1] = x*100; }
if(i==17){ y[3][2] = x*10; }
if(i==18){ y[3][3] = x; }
d= y[3][0]+y[3][1]+y[3][2]+y[3][3];
if(i==18){ Serial.print(" corner d: ");Serial.println(d);Serial.println("");}
i++;
} All files are on Github HERE.
GOAT INDUSTRIES
