while(digitalRead(soundPin) == LOW){
//keep the doppler effect mode activated
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
//get data
vib = abs(gz)/1000; //the gz variable is actually accelerator data
//this is calibrated though the division and simplified to use by absolute value
if(vibEnable == 1 && vib >= 2){
//though "blinking" the vibrato/doppler effect is simulated
//this activates only, when the calibrated acceleration value exceeds 1
myservo.write(vib*6 + 6); //outputs the digitally calculated value to the servo which feeds the analogue theremin circuit.
vibEnable = 0;
}else{
myservo.write(vib*6 - 6);
vibEnable = 1;
delay(20); // this is necessary, because the servo requires some time to move (about 60 degrees per second)
Could you share some code on the doppler effect simulations? Right now I'm only using tone() for that plus the mpu6050...
