This isn't really an update on the project just a new image. I have wanted to be able to render KiCad files in Blender for a while but have never gotten around to it. I spent some time today to figure it out and this is the output. This is done using the cycles render engine. Hopefully I can make a more techy environment than just the gray metal.
julien
Hi, very nice rendering in Blender :)
Would you mind to share the .blend file here or in GitHub?
I like the environment and I would like to replicate it for some rendering...
Thank you
Maurice
P.S. if you need an enclosure design for your project you may have a look at my kicad StepUp script
https://hackaday.io/project/7926-kicad-stepup-script-hacks-mcad-world
Hey, thanks for the link! I have to design an
enclosure for another project and I going to try and do it in FreeCad.
This will help for sure!
do was
The ones for this project turned out better.
https://hackaday.io/project/9455-poepi-pi-zero-power-over-ethernet-with-phy
I have added the .blend file there let me know what you think of that project I am try to get some feedback :)
