Fixed Bug
01/15/2016 at 18:27 • 0 commentsThe original code used port 1 pin 0 and 1 to control the paddle. These 2 pins can't be used with internal pullup and the paddle was drifting around. Changed the paddle control to port 1 pin 2 and 3.
Done
01/06/2016 at 20:35 • 0 commentsTested it, updated code and uploaded pictures.
This was just a quick demo of how to quickly build a stand-alone project with BotSpine.
A tethered example will follow.
Built Hardware and Tested Code
01/06/2016 at 00:37 • 0 commentsThere were some bugs in the code. That's sorted out now. It is sooooo much easier to debug in an interpreter, on the device, than doing the edit-compile-upload-test, edit-compile-upload-test cycle.
Still optimizing. Will add some pictures and update the code in a couple of days. And, yes, it does fit into a matchbox.
