IMU Sens
04/07/2018 at 17:01 • 3 commentsHere is how it looks like the IMU sens placed on the PCB TOP.
It has multiple redundant accelerometers and gyroscopes.It is placed on dumpers for vibrations absorptions.
PCB TOP / Raspberry Pi Compute Module Socket
04/01/2018 at 22:52 • 0 commentsThe PCB TOP has a socket to host the Raspberry Pi compute module
It is connected to :
- a micro USB for booting
- a USB-A for peripheral (not soldered yet)
- two Raspberry Pi Cameras (not soldered yet)
The power of the compute is provided by two LDO 1v8 and 2v5. The 3v3 is directly provided by the PCB Bottom. -
PCB TOP Assembled (part 1)
04/01/2018 at 22:04 • 0 commentsI assembled the following parts of the PCB TOP:
- the SAME70-M1/M2 circuits
- the headers of the xBees
- the connector for front sens
- the RPi Cams connectors
- the Raspberry Pi compute module socket and circuit
- the radio Si4464 -
The weight
03/24/2018 at 09:45 • 0 commentsThe weight matters ᕙ(° ͜ಠ ͜ʖ ͜ಠ°)ᓄ
The PCBs of the fliying part is around 110g
I will see how it will become when I finish the assembly
Just got the PCBs
03/24/2018 at 09:31 • 0 commentsI've received the PCBs, shall now start the assembly!
Got the font sens PCB
03/23/2018 at 20:38 • 0 commentsJust got the PCBs of the front sens, the assembly will follow.
The Raspberry Pi Cameras will be placed in the front, hopfully to do stereo vision with the compute module.
There will be also sensors (gas, temperature, baro in there).
Plof
03/22/2018 at 17:07 • 0 commentsNothing for the moment, waiting for the pcbs to arrive (expected tomorrow).
I got the bom.
The iron and oven are warming.Next step the assembly, then the software integration.
BANANA CONNECTORS
03/21/2018 at 19:01 • 0 commentsFor this version I will use only the soldered wire with banana connector.
Next time I will use directly PCB soldered bana connector for LiPo and Motors. -
DRONI SAME70Pi / 1.ELECTRONICS / IMU SENS
03/21/2018 at 18:35 • 0 commentsThis small piece of beauty is the graal of the project.
A full redundant 3xIMU + baros.Quite small, it uses dumpers to get fixed on the TOP PCB of the drone.
We keep a little delta between the two holes of fixation 2mm Y axis, and 3mm X axis. The reason is to have a small stress to keep the equilibrium of the IMU SENS.I use the 2xBMI160:
DRONI SAME70Pi / 1.ELECTRONICS / REMOTE CONTROLLER (UPDATE)
03/21/2018 at 16:34 • 0 commentsThe analog joysticks that will be used are the same replacement for Fr'sky ones
