trs80sd-20180727a.zip
****added hrg syscalls feature**** SD card filesystem contents; unzip into the root of a microSD (up to 32 Gb), to have requisite files in place for the emulator to be useful. Firmware images and the boot loader exe in 'doc'. These are not required for the emulator of course (the image has to be burned onto the chip!), but I put them in here for convenience to causally interested parties, to avoid downloading the source, setting up the toolchain, and building. Operation of the bootloader exe (Windows) is intuitively obvious. It's HID-based, so no drivers are needed. It does not appear to be usable on XP alas, so you'll need win 7 and up. There is also a 'README.txt' in the 'doc' folder which explains things in more detail.
x-zip-compressed - 29.41 MB - 07/27/2018 at 19:12
Download
trs80sd-20180526a.zip
****added bitmap screen cap feature**** SD card filesystem contents; unzip into the root of a microSD (up to 32 Gb), to have requisite files in place for the emulator to be useful. Firmware images and the boot loader exe in 'doc'. These are not required for the emulator of course (the image has to be burned onto the chip!), but I put them in here for convenience to causally interested parties, to avoid downloading the source, setting up the toolchain, and building. Operation of the bootloader exe (Windows) is intuitively obvious. It's HID-based, so no drivers are needed. It does not appear to be usable on XP alas, so you'll need win 7 and up. There is also a 'README.txt' in the 'doc' folder which explains things in more detail.
x-zip-compressed - 29.40 MB - 05/26/2018 at 17:20
Download
trs80sd-20180515a.zip
****adds screen cap capability**** SD card filesystem contents; unzip into the root of a microSD (up to 32 Gb), to have requisite files in place for the emulator to be useful. Firmware images and the boot loader exe in 'doc'. These are not required for the emulator of course (the image has to be burned onto the chip!), but I put them in here for convenience to causally interested parties, to avoid downloading the source, setting up the toolchain, and building. Operation of the bootloader exe (Windows) is intuitively obvious. It's HID-based, so no drivers are needed. It does not appear to be usable on XP alas, so you'll need win 7 and up. There is also a 'README.txt' in the 'doc' folder which explains things in more detail.
x-zip-compressed - 29.40 MB - 05/16/2018 at 02:09
Download
trs80sd-20180510a.zip
****adds traps for Level I, and sundry config enhancements**** SD card filesystem contents; unzip into the root of a microSD (up to 32 Gb), to have requisite files in place for the emulator to be useful. Firmware images and the boot loader exe in 'doc'. These are not required for the emulator of course (the image has to be burned onto the chip!), but I put them in here for convenience to causally interested parties, to avoid downloading the source, setting up the toolchain, and building. Operation of the bootloader exe (Windows) is intuitively obvious. It's HID-based, so no drivers are needed. It does not appear to be usable on XP alas, so you'll need win 7 and up. There is also a 'README.txt' in the 'doc' folder which explains things in more detail.
x-zip-compressed - 29.36 MB - 05/11/2018 at 03:32
Download
