Hackaday.io Hackaday.io
Sign up Log in
MQTT WiFi controlled mains halogen dimmer
MQTT WiFi controlled mains halogen dimmer that can be controlled by rotary controller or from home automation (OpenHab) by PIC and ESP8266
marc-spoorendonkMarc Spoorendonk
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.7k views
0 comments
845 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.7k
0
845
1
Team (1)
  • marc-spoorendonkMarc Spoorendonk
Join this project's team
hardware
ongoing project
pic ESP8266 mqtt openhab
This project was created on 01/06/2016 and last updated 3 years ago.
Description
MQTT WiFi controlled mains halogen dimmer that can be controlled by rotary controller or from home automation (OpenHab) by PIC and ESP8266. The 300W halogen lamp is dimmed on the primary side of a round (conventional) transformer. The dimming electronics are decoupled from the mains for easy debugging. The zerocross signal is taken from the secondary side of a small transformer that also supplies the circuit with about 3.7V (old phone charger).
Components
  • 1 × ESP8266 wifi tranceiver
  • 1 × PIC16F628A Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × MOC3032 optocoupler Opto and Fiber Optic Semiconductors and ICs / Optocouplers and Optoisolators
  • 1 × Triac Discrete Semiconductors / Thyristors (DIACs, SIDACs, TRIACs, SCRs)
Project Logs
Collapse
  • Mains part built. Now testing.
    Marc Spoorendonk • 02/10/2016 at 22:22 • 0 comments
    The mains part with the triac is now built on perfboard. Works fine. A small reallife test showed that it also works on the 300W halogen transformer. Had to pull an extra nullwire as it wasn't present at this location.
  • Learning Fritzing
    Marc Spoorendonk • 02/07/2016 at 19:57 • 0 comments
    Learning how to use Fritzing in order to create a small perfboard to test the high-voltage part on the 300W halogen lamp.
  • ESP8266 blinking
    Marc Spoorendonk • 01/06/2016 at 20:55 • 0 comments
    Got the ESP-102 to work with Arduino IDE. Now make it speak to the PIC at 9600 baud.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
ESP8266 NodeMCU baseboard for adding some physical control to your home automation projects
Project Owner Contributor
MQTT NOAH Baseboard
dewetDewet
iDon't as in I don't want my doorbell to ring.
iDONT (Internet Doorbell ON/off Trigger)
david-spindenDavid Spinden
Simple and cheap configurable ESP32 based controller for wired sensors and relays
Chipperb
jason-kJason K
The 2017 Hackaday Prize
Use DFRobots 4 Channel relay shield and control up to 4 appliances using just a infrared remote controller.
IR Home Automation on DFRobot's Relay Shield
naman-chauhanNaman Chauhan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MQTT WiFi controlled mains halogen dimmer", please tell us the reason.
Send message
Remove Member
