Mains part built. Now testing.
02/10/2016 at 22:22 • 0 commentsThe mains part with the triac is now built on perfboard. Works fine. A small reallife test showed that it also works on the 300W halogen transformer. Had to pull an extra nullwire as it wasn't present at this location.
Learning Fritzing
02/07/2016 at 19:57 • 0 commentsLearning how to use Fritzing in order to create a small perfboard to test the high-voltage part on the 300W halogen lamp.
ESP8266 blinking
01/06/2016 at 20:55 • 0 commentsGot the ESP-102 to work with Arduino IDE. Now make it speak to the PIC at 9600 baud.
