Hackaday.io Hackaday.io
Sign up Log in
DIY Soldering Station Musings
A collection of ideas/projects and my personal take on it
stefan-lochbrunnerStefan Lochbrunner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
13.5k views
8 comments
23 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 8
View Gallery
13.5k
8
23
13
Team (1)
  • stefan-lochbrunnerStefan Lochbrunner
Join this project's team
hardware
ongoing project
soldering station Hakko 907
Related lists
Soldering Tools
Molten Metal - the lifeblood of electronics work
rt usb_c soldering iron
soldering irons based onthe weller rt tip or things with usb c /pd/qc3.0
otros
otros varios
This project was created on 01/08/2016 and last updated 10 years ago.
Description
I've been going back and forth between building my own or just buying an affordable one but after seeing the one on the blog (somewhat) recently (http://hackaday.com/2016/01/05/diy-hakko-soldering-station/) I finally made the decision to go with the first option.
I'm not sure how much originality I can add to the topic but I figure a sort of literature review - if you will - might be worthwhile and helpful to others looking into building one.
Everything is quite rough at the moment but until I refine it a bit more check out the links themselves for more info.
If you have some more info on this topic that is not already covered, please let me know.
Project Logs
Collapse
  • R-T-Curve
    Stefan Lochbrunner • 03/07/2016 at 21:16 • 0 comments
    I made a quick measurement to see how linear the iron's temperature sensor is. Since I don't have a thermocouple I used a Pt1000 strapped to the heating element like this:
    So I had one DMM measure the Pt1000's resistance and another one measure the resistance of the iron's sensor. Afterwards I calculated the temperature from the Pt1000's values and came up with this graph:
  • Component sources
    Stefan Lochbrunner • 02/18/2016 at 20:11 • 0 comments
    just some notes, can probably be moved to components section once finalized
    • Soldering iron/ handle - eBay: http://www.ebay.de/itm/331737608656
    • DIN connector - eBay: http://www.ebay.de/itm/201365480597
    • MOSFET + heat sink - spare parts
    • Arduino Pro Mini - spare part/ eBay: http://www.ebay.de/itm/200957063666
    • OpAmp - ?
    • PSU - pwr from ATX bench PSU? Laptop pwr brick?
    • Display - spare part
    • Voltage regulator - spare part?
    • PCB - perfboard + modules/ fabbed PCB?
  • The (in)complete list of DIY soldering station projects to rule them all
    Stefan Lochbrunner • 01/08/2016 at 23:01 • 1 comment
    I might be falling into a pattern...
    For now I just want to collect all the sources in one place. The list is somewhat sorted but hopefully I'll go over this list again and summarize all/most of them and maybe do some more sorting.
    A quick heads up: There are a lot of duplicate links but I wanted to document for myself how/where I found the projects.
    Hakko 907:
    • I already mentioned this one which was featured on the blog - I really like the option of driving two irons and the author makes a good point for the analog dial. He also proposes a mod for better heat conduction between the heating element and the tip.
    • Right now I'm thinking whatever I'll end up building is going to be very close to #Hakko 907 based Soldering Station because it's very straight forward.
      • derivative: https://hackermagnet.com/portfolio/soldering-station/
    • http://elco.crsndoo.com/wordpress/2012/01/soldering-iron-driver-gen3-rev1-4/, via http://dangerousprototypes.com/2011/10/25/hakki-907-and-compatible-soldering/
    • #Soldering Iron Controller - (light on info) / more info: http://www.zl2pd.com/SolderingStation.html - (analog & digital control), via http://hackaday.com/2015/09/02/a-tale-of-three-soldering-iron-controllers/
    • #Mobile temperature controlled soldering iron - links for components
    Hakko T12
    • http://dangerousprototypes.com/forum/viewtopic.php?f=56&t=5264&start=180#p58264 / http://dangerousprototypes.com/2014/07/01/hakko-t12-soldering-controller/
    • #70W Soldering Iron Controller / http://smdprutser.nl/project/70w-soldering-iron-controller/
    • @Stefan Wagner's #Soldering Station and #TinySolder
    Weller RT:
    • http://www.martin-kumm.de/wiki/doku.php?id=Projects:SMD_Solderstation, via http://dangerousprototypes.com/2014/05/29/smd-soldering-station-for-weller-soldering-tips/
    • https://debugginglab.wordpress.com/2014/10/30/soldering-station/ / https://github.com/ConnyCola/SolderingStation - based on above, very nicely thought out (has standby feature), PCBs on DirtyPCBs
      • derivative: https://github.com/PostTenebrasLab/SolderingStation
    • http://hackaday.com/2015/05/11/hacking-amazing-soldering-features-into-the-already-great-weller-wmrp/
    • #Soldering pen by @HP (@banjohat) - also based on the one by [Martin Kumm] linked above, very cool idea of integrating all the controls in the handle, made me think about applying this concept to the 907 iron/handle
    • See also the projects in @Teslafly's list rt usb_c soldering iron
    Weller WSP80:
    • http://www.eosystems.ro/index.php/projects/esol - uses MCU's internal PGA
    • #Yet another DIY soldering station by @SUF - expected to have 3 (!) soldering irons and a bunch of other useful features, especially like the ideas to reduce energy consumption
    Modded mains soldering iron:
    • https://pcbsmoke.wordpress.com/2015/10/03/diy-110v-temperature-controlled-soldering-station/, via http://dangerousprototypes.com/2015/10/05/diy-110v-temperature-controlled-soldering-station/
    • https://pcbsmoke.wordpress.com/2015/08/03/soldering-iron-temperature-controller-version-2/
    • https://pcbsmoke.wordpress.com/2015/07/12/diy-digital-soldering-station/, via http://dangerousprototypes.com/2015/07/14/diy-digital-soldering-station/
    • https://pcbsmoke.wordpress.com/2015/06/04/soldering-iron-pulse-timer-temperature-control/, via http://dangerousprototypes.com/2015/06/05/soldering-iron-pulse-timer-for-temperature-control/
    • https://pcbsmoke.wordpress.com/2015/04/21/soldering-iron-pid-temperature-controller/, via http://dangerousprototypes.com/2015/04/27/soldering-iron-pid-temperature-controller/
    • #Entry Level Electronics -- Improve your Iron
    Misc:
    • http://poormanelectronics.blogspot.ro/p/pm-soldering-station.html
    • http://dangerousprototypes.com/2016/02/03/unisolder-5-2/ - universal controller
    • @monsterome's list SOLDERING STATION DIY
    While I focused on soldering stations here, you might also want to check out the official soldering-tools list if you haven't already.
    Edit 2016-03-28: Added #Soldering pen
    Edit 2016-03-28 #2: Added http://www.eosystems.ro/index.php/projects/esol...
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
SUF wrote 03/28/2016 at 18:46 • point
Stefan: Don't leave this out:
Stefan Lochbrunner wrote 03/28/2016 at 19:41 • point
Thanks for the tip!
Clovis Fritzen wrote 03/06/2016 at 00:25 • point
Thank you for concentrating the resources in one place!. I personally have two hakko irons coming from China and want to assemble then a station; will be looking at your work!
Stefan Lochbrunner wrote 03/06/2016 at 01:14 • point
Glad to hear you have some use for this :)
I'm very interested to see your take on a station with two irons!
Clovis Fritzen wrote 03/06/2016 at 01:35 • point
Actually it will be one iron at a time  :) . I bought two just in case
Stefan Lochbrunner wrote 03/06/2016 at 10:53 • point
I thought about extending my station to two irons once it's done but having spare parts on hand is definitely a good call. Now I wonder what parts of these cheap irons are most prone to failure; since you can buy pretty much all parts individually it might suffice to stock up on the weak ones.
davedarko wrote 03/05/2016 at 14:17 • point
Wow, what a list :)
Stefan Lochbrunner wrote 03/05/2016 at 14:19 • point
Maybe you can tell that I've been working on this for a while before releasing it ;)
Small, simple and inexpensive preheat plate for hot-air soldering
Project Owner Contributor
Soldering preheat plate
jaromirsukubajaromir.sukuba
Slapping a 10uH inductor was meant to be easy. But increasing the temperature, 30% variability strikes and you cry..
PCB Inductors vs. Temperature and.. Irrigation
mgMG
Repurposing a low cost slow cooker to provide a simple (and maybe a more energy efficient) way to reflow PCB's
Using a Slow Cooker to reflow your PCB's
gerriko-ioGerriko IO
The 2018 Hackaday Prize
Building a smarter, smaller and more user friendly soldering station
Hakko revenge
marius-taciucMarius Taciuc
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Soldering Station Musings", please tell us the reason.
Send message
Remove Member
