1Get Unity
You should have a recent (2017 or 2018 beta) version of Unity on your machine. If not Get One
2Get IBM Login
If you dont have an IBM web service id... Get One
3Setup Watson SDK in Unity
Follow instructions on the GitHub Page
4Play with their examples
The Watson>Examples folder has some scenes to try out the services. You will need to enter your Credentials into the C# scripts. Do a bit of poking around so you a) prove your credentials work b) have basic familiarity with the examples to drive the services.
Jerry Isdale
