Finished product
01/17/2016 at 23:03 • 0 commentsEverything (except the backing) was sanded, primed with black primer, the center gear was then painted with Krylon Antique Brass spray paint and the three small gears were painted with a few coats each with Krylon metallic paint pens. All the gears were then sealed with a Krylon matte finish clear coat (no, I don't work for Krylon, it is just what they had when I want paint shopping).
I had picked up some XTC-3D filler, but I did not have the time to use it before I needed these for the party.
The backing fit perfectly under the lapel of the frock coat I had rented, I used some of the extra gears I had printed in silver filament to make some last minute cufflinks (not pictured).
The lapel gears worked great all not, I only bumped one off all night and noticed right away that I did. They turned perfectly against the fabric of the coat and they were a big hit. I am really happy with how this turned out and I give big Thanks to the projects that inspired me and the designer of the gears!
Log 2
01/11/2016 at 00:19 • 0 commentsPainting is done! I still need to seal all the pieces, but it is raining out and I need everything to dry better first.
Here are some images and a gif of the action. you can see the magnets on the backside of the backing plate (on the right).
Log 1 - Starting
01/10/2016 at 20:09 • 0 commentsI took zheng3's design, printed it at 200% (but only 100% z-axis) and printed one large gear and 3 of the small gears. I then created a 3-pointed backing and some caps to fit on either side of the magnets to hide them.
I printed the gears, used my awesome Bondic pen to glue in the caps on the back of the gears to hold them in place, press fit the magnets (I had a bunch of 1/2"x1/16' neodymium magnets around) press fit and glued (Bondic) the caps to cover the magnets. I sanded all the gears and I am currently waiting for the 3rd coat of Krylon Matte Black spay to dry.
The plan is to do the large center gear in Krylon Antique Brass and the other 3 will be done with gold, silver and copper paint pens and then all will be sealed with a clear coat.
Here is a pic of the unpainted gears clipped to my shirt for testing. You can see the magnets on the three small gears as I had not put the top caps on yet. The backing is under my shirt and has 4 magnets aligned with the 4 gears.
