If you care at all about performance, the Arduino built in pin output function (digitalWrite) is not fast enough. Luckily, many fast IO implementations exist. I am using this one:
https://github.com/mikaelpatel/Arduino-GPIO
https://github.com/mikaelpatel/Arduino-GPIO/blob/master/src/Hardware/AVR/GPIO.h
The pins have to be declared as individual objects, which looks scary at first, but a display function can be created to display any number on any position.
GPIO<BOARD::D5> SegmentA;
GPIO<BOARD::D8> SegmentB;
GPIO<BOARD::D10> SegmentC;
GPIO<BOARD::D19> SegmentD;
GPIO<BOARD::D9> SegmentE;
GPIO<BOARD::D6> SegmentF;
GPIO<BOARD::D14> SegmentG;
GPIO<BOARD::D18> SegmentDP;
GPIO<BOARD::D2> Digit1;
GPIO<BOARD::D3> Digit2;
GPIO<BOARD::D4> Digit3;
GPIO<BOARD::D17> Digit4;
GPIO<BOARD::D16> Digit5;
GPIO<BOARD::D7> Digit6;
GPIO<BOARD::D15> Digit7;
GPIO<BOARD::D11> Digit8;
GPIO<BOARD::D12> Digit9;
The pins are initialized in the following functions:
void allSegmentOutput() {
SegmentA.output();
SegmentB.output();
SegmentC.output();
SegmentD.output();
SegmentE.output();
SegmentF.output();
SegmentG.output();
SegmentDP.output();
void allSegmentOff() {
SegmentA.high();
SegmentB.high();
SegmentC.high();
SegmentD.high();
SegmentE.high();
SegmentF.high();
SegmentG.high();
SegmentDP.high();
void allDigitOutput() {
Digit1.output();
Digit2.output();
Digit3.output();
Digit4.output();
Digit5.output();
Digit6.output();
Digit7.output();
Digit8.output();
Digit9.output();
void allDigitOff() {
Digit1.low();
Digit2.low();
Digit3.low();
Digit4.low();
Digit5.low();
Digit6.low();
Digit7.low();
Digit8.low();
Digit9.low();
To use them, call outputDigit to put the correct bits for a number in the bus, then call selectDigit to activate the correct anode.
byte outputDigit(signed char digit, bool decimalpoint = false) {
byte segmentslit = 0;
allDigitOff();
if (decimalpoint)
segmentslit++;
SegmentDP.low();
else
SegmentDP.high();
switch (digit) {
case 0:
SegmentA.low();
SegmentB.low();
SegmentC.low();
SegmentD.low();
SegmentE.low();
SegmentF.low();
SegmentG.high();
segmentslit += 6;
break;
case 1:
SegmentA.high();
SegmentB.low();
SegmentC.low();
SegmentD.high();
SegmentE.high();
SegmentF.high();
SegmentG.high();
segmentslit += 2;
break;
case 2:
SegmentA.low();
SegmentB.low();
SegmentC.high();
SegmentD.low();
SegmentE.low();
SegmentF.high();
SegmentG.low();
segmentslit += 5;
break;
case 3:
SegmentA.low();
SegmentB.low();
SegmentC.low();
SegmentD.low();
SegmentE.high();
SegmentF.high();
SegmentG.low();
segmentslit += 5;
break;
case 4:
SegmentA.high();
SegmentB.low();
SegmentC.low();
SegmentD.high();
SegmentE.high();
SegmentF.low();
SegmentG.low();
segmentslit += 4;
break;
case 5:
SegmentA.low();
SegmentB.high();
SegmentC.low();
SegmentD.low();
SegmentE.high();
SegmentF.low();
SegmentG.low();
segmentslit += 5;
break;
case 6:
SegmentA.low();
SegmentB.high();
SegmentC.low();
SegmentD.low();
SegmentE.low();
SegmentF.low();
SegmentG.low();
segmentslit += 6;
break;
case 7:
SegmentA.low();
SegmentB.low();
SegmentC.low();
SegmentD.high();
SegmentE.high();
SegmentF.high();
SegmentG.high();
segmentslit += 3;
break;
case 8:
SegmentA.low();
SegmentB.low();
SegmentC.low();
SegmentD.low();
SegmentE.low();
SegmentF.low();
SegmentG.low();
segmentslit += 7;
break;
case 9:
SegmentA.low();
SegmentB.low();
SegmentC.low();
SegmentD.high();
SegmentE.high();
SegmentF.low();
SegmentG.low();
break;
segmentslit += 5;
case 10:
SegmentA.high();
SegmentB.high();
SegmentC.high();
SegmentD.high();
SegmentE.high();
SegmentF.high();
SegmentG.low();
segmentslit += 1;
break;
case 99:
SegmentA.high();
SegmentB.high();
SegmentC.high();
SegmentD.high();
SegmentE.high();
SegmentF.high();
SegmentG.high();
break;
default:
allSegmentOff();
break;
return segmentslit;
byte lastSelectDigit = 0;
void selectDigit(byte digit) {
lastSelectDigit = digit;
allDigitOff();
allDigitInput();
switch (digit) {
case 1:
Digit1.high();
Digit1.output();
break;
case 2:
Digit2.high();
Digit2.output();
break;
case 3:
Digit3.high();
Digit3.output();
break;
case 4:
Digit4.high();
Digit4.output();
break;
case 5:
Digit5.high();
Digit5.output();
break;
case 6:
Digit6.high();
Digit6.output();
break;
case 7:
Digit7.high();
Digit7.output();
break;
case 8:
Digit8.high();
Digit8.output();
break;
case 9:
Digit9.high();
Digit9.output();
break;
