1Step 1
Browse around on the hackaday page, and read the Gitbook to learn more at first
2Step 2
Make/order a pulser module, as well as a analog processing module. Make files are on github.
In the meanwhile, prepare the motherboard, with a simple stripboard, using the tracks convention.
3Step 3
Prepare the microcontrolers with the code, especially the rapid ADC microcontroler. With an optional oscillo OLED screen if you want. Should look like this:
Alternatively, use a Beaglebone PRUDAQ to acquire the raw signal.![]()
4Step 4
Plug in the transducer and the servo.
5Step 5
And you're good to get images!
kelu124
