1Step 1
By using "Dremel circle cutter" cut two plastic circles
177mm Diameter for pressure sensitive surface
155mm Diameter for bottom base
In my case I build my own circle cutter
check video for details https://www.youtube.com/watch?v=D8kZFAhsS1g
2Step 2
Electronics
Just duplicate my circuit analogously to hi-res pics ;)
I will update this page with schematic.
3Step 3
IR distance sensor
Drill hole with drill then by using file make it rectangular.
Insert R distance sensor connector in rectangular hole with super glue.
4Step 4
Done! Upload code and have fun.
Code is coming on next week.
Thank you for watching!
5Step 5
Align servo like on the picusing a ruler and pencil rod
6Step 6
Modify servo for continuous rotation
Take apart servo and remove small tab from the large gear
7Step 7
Make the following setup
Upload a code to arduino with myservo.write(90);
Then stop the servo by rotating pot
Glue servo shaft with small amount of super glue.
Do not insert pot shaft as it was before. just place pot diagonally into servo cavity.
Assemble servo. -
8Step 8
RC servo to base mount.
Draw the next drawing on a bottom base
9Step 9
10Step 10
Super Glue it
txyz.info
