1Step 1
Web server stuffs
- Compile appropriate version of Nginx source with rtmp module
- Configure /etc/nginx.conf in order to use as rtmp server
2Step 2
Cam stuffs
- Install raspi camera hardware module to CSI port on board
- Compile appropriate version of ffmpeg source
3Step 3
Scripting stuff
- Implement a bash script by using both of raspivid and ffmpeg commands.
4Step 4
Test
- For android, install MX Player app from Play.
- In MX Player menu on the upper right, entry rtmp stream URL to Network Stream menu label.
