1Step 1
Sensor stuffs
- Functional tests of knock/vibration sensors on arduino board
- Cabling of knock/vibration sensors
- Get analog values from knock/vibration sensors on Raspi
- Functional tests of sound sensors on arduino board
- Cabling of sound sensors
- Get analog values from sound sensors on Raspi
2Step 2
Cam stuffs
- Func test of USB cam on board
- Gain ability to take photo by using ffmpeg with appropriate resolution
3Step 3
Image processing (optional, if i can)
- Compare photos in between pre-saved gallery and currently took ones
- Entry guest name as label on photo by using ffmpeg
4Step 4
Social network stuffs
- Select a social platform API e.g. instagram, twitter, whatsapp
- Install python API to the board
- Implement code to share photo from the board
5Step 5
GUI stuffs
- Uninstall desktop environment and desktop manager from Raspian
- Implement Qt-based UI app for 3.5" LCD of the board
- Integrate 1st,2nd and 3rd step's stuffs that written above to GUI app
- Configure startup scirpts to initilazize project works
6Step 6
Installation and test stuffs
- Supply system via battery bank
- Assembly system to the entrance door at height level compatible 3 years old-boy
- Supply system via a battery bank
- Fix camera to the door peephole
- Place vibration and sound sensors to most effective points
