I2C hat with INA3221 sensor for Banana Pi
A project log for Solar Charge Controller MPPT Test Facility
A Banana Pi- based system designed to test the performance of solar charge controllers
tobiasTobias 01/27/2016 at 00:250 Comments
This hat was designed with Eagle Cad (see Files) and made with the Zen Toolworks CNC.
Code: see links. Note: the code from switchdoc.com works with the Banana Pi, but you have to change to bus number 2 (already done in my code).
