close up of the X Axis drive
JPEG Image -
328.70 kB -
06/25/2016 at 22:30
Preview
got power supply, 12V 30Amp, probably more then I'll need for the amps, but we'll see. Got arduino and 3 stepper drives prepped for doing some dual axis manual motion.
JPEG Image -
341.76 kB -
06/25/2016 at 22:30
Preview
just a close up at the way the angle bracket is secured to the rail at the top of the gantry
JPEG Image -
326.26 kB -
04/03/2016 at 01:24
Preview
Just a view of a hole I drilled through the MDF cross beam so that I could tighten up the screws and nuts holding the angle bracket on the gantry.
JPEG Image -
329.97 kB -
04/03/2016 at 01:24
Preview
This was the first screw access hole I drilled I was only able to get to one of the screws so I HAD to drill a second as picture in photo SAM_684
JPEG Image -
331.98 kB -
04/03/2016 at 01:24
Preview
Latest full frontal view
JPEG Image -
337.80 kB -
04/03/2016 at 01:24
Preview
View showing the Z and X axis fully extended, but they do go beyond the working area
JPEG Image -
333.39 kB -
04/03/2016 at 01:24
Preview
Same idea as in SAM_0686 just a different type of deck angle bracket, it was too wide to use on the MDF at the top of the gantry.
JPEG Image -
318.88 kB -
04/03/2016 at 01:24
Preview
Just a view of an angle bracket, normally used for decks to help hold / tighten this join between the MDF and 2 X 4
JPEG Image -
331.13 kB -
04/03/2016 at 01:24
Preview
something of a top view shot, new base plate and one of the x axis slides in place
JPEG Image -
332.90 kB -
03/30/2016 at 00:16
Preview
better view of the left side where the z axis is controlled from
JPEG Image -
334.85 kB -
03/30/2016 at 00:16
Preview
JPEG Image -
341.28 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
326.04 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
343.69 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
338.70 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
341.90 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
334.05 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
323.55 kB -
03/04/2016 at 03:17
Preview
JPEG Image -
344.24 kB -
03/04/2016 at 03:17
Preview
