How i came up with the idea?
07/15/2018 at 06:24 • 0 commentsThis is the drone concept that gave me the idea of trying to create the PCB motor and spherical folding propeller! Both of these projects need a lot more work and improvement to make this drone feasible but at least now I have a starting point :)
Thrust Test
03/25/2018 at 21:13 • 0 commentsThis is the thrust results of the first Spherical Folding Propeller prototype:
The results are not so bad considering the size of the propeller (1.6cm diameter when folded) and that no air-flow simulations were done during design. I'm going to conduct simulations for the next prototype, to try and make the propeller as efficient as possible.
This is the setup used to measure the thrust. The propeller was suspended around 15cm above the scale, to eliminate ground effect.
First Test
03/23/2018 at 00:25 • 0 comments -
Dimensions
03/23/2018 at 00:24 • 0 commentsThe first prototype has a sphere of 16mm diameter. When the blades are opened, the propeller has a total length of around 3.7cm. Its total weight is around 0.6 grams.
Assembly
03/22/2018 at 23:12 • 0 commentsThe first Spherical Folding Propeller prototype is made from:
- 1 3D-Printed Bearing-Holder
- 2 3D-Printed Blades
- 2 SMF681X-ZZ Bearings
First 3D-Printed Prototype Parts
03/22/2018 at 23:06 • 0 comments
Carl Bugeja
