home automation version 1.0
control home appliances with TV remote
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
control ur home lighting , fan and AC with Tv or any ir remote using arduino
Main component
1.arduino
2.relay
3.lm358
4.preset
5.photodiode
6.resistors
7.led
8.bc 548
9.diod
10.general purpose board
11.9v battery
12.any ir remote
CODE
/*created by shanu singh
shanu12.kumar@gmail.com
turn on a LED when the button is pressed and let it on
until the button is pressed again
int pinButton = 8;
int LED = 13;
int stateLED = LOW;
int stateButton;
int previous = LOW;
long time = 0;
long debounce = 200;
void setup() {
pinMode(pinButton, INPUT);
pinMode(LED, OUTPUT);
void loop() {
stateButton = digitalRead(pinButton);
if(stateButton == HIGH && previous == LOW && millis() - time > debounce) {
if(stateLED == HIGH){
stateLED = LOW;
} else {
stateLED = HIGH;
time = millis();
digitalWrite(LED, stateLED);
prev
Rich text editor
