So far we have the following elements :
- Power-On Reset: a few parts (1 N-FET, 1M, 10µ, 1 diode)
- Oscillator : a few transistors, maybe a dozen of parts. Parts count and power draw are not significant because it's only one circuit.
- Divider: 15 stages of divide-by-two, 12 parts each : 180 parts (4P, 6N,2R=> 60 P-FET, 90 N-FET, 30×100K)
- AND2 for MUX decoding: 3× 4T=12 (6P-FET, 6N-FET)
- 2+5+3+5+3+5=23 stages of Johnson counters with reset: 13 parts×23=299 (23 diodes, 92P-FET, 138 N-FET, 46×100K)
- 46 partial AND2: 92 N-FET
- 6×digit enable (2N) = 12 N-FET
- 6×7 LED (41 actually)
- LED decoding matrix: 17 diodes, 7×10K
- Low-side LED drivers (7 N-FET, 7×1K)
- High-side digit enable (6 P-FET, 6×10K)
- 6 buttons to advance each digit + electronics
Total:
- about 360 × N-FET (2N7002)
- 164 × P-FET (BSS84)
- 1M Resistor
- 90×100K resistors
- 7× 1K resistors
- 41 diodes (1N4148 or better, I have Schottky aplenty)
- 41 LED
That's 700 parts !
OK that's a LOT but almost half http://www.transistorclock.com/ that contains 1257 parts.
