Made a Prototype :)
05/11/2014 at 20:01 • 0 commentsI finally etched the board and soldered everything I had at home (the micro usb socket and the attiny are on their way ;D )
Also I managed to fit the sot23 version of the zener diodes on normal 1206 pads (I had 3000 of them at home...)
After etching:
After cleaning & silver-plating:
And finally after cutting and populating:
The pinheader is glued to the board using super-glue.
Touch it!
04/29/2014 at 19:41 • 0 commentsI made a version of the board with a touch sensor and a programmable led on board to make it a bit more useful as a little development board :)
XDjackieXD
