Working clock
A project log for GPS Nixie Alarm Clock
GPS controlled nixie alarm clock with IR-receiver
tobias-rathjeTobias Rathje 02/09/2016 at 16:230 Comments
Board updated with GPS module, and now the clock works. The LED is on when GPS fix is obtained, and flashes at 1 Hz when no signal is received. TIMER1 is configured to overflow every second, and a timer interrupt is set up to call system_tick() so the clock is running when there is no GPS signal.
Rich text editor
