battery box 2.STL
externally mounted battery box because its a ball ache taking your rover apart every time the batteries die.
Standard Tesselated Geometry -
289.14 kB -
04/08/2016 at 10:06
Download
line_sense1.ino
first go at taking readings from analog sensor array. the two sensors disabled by // dont work properly but i left the code in. Also, there is a big delay between readings so it is easy to see what is happening in serial monitor.
ino -
2.38 kB -
04/02/2016 at 12:49
Download
analogpwmconcept.ino
arduino sketch to explore analogue read and analogue write commands. its not perfect but it works...
ino -
939.00 bytes -
02/24/2016 at 14:12
Download
teensy holder v4.3.STL
Mount for a teensy 3.1. Teensy can be mounted both ways up, 3.2mm mounting holes fit raspberry pi 2 (length and width), also holes 10mm apart and 20mm apart.
655.06 kB -
02/19/2016 at 14:28
Download
dagu mounting board.STL
A mounting board for a raspberry Pi 2 B and an L298 driver to be mounted on a dagu rover chassis. also fits a 4xaa battery box or one of the powerpacks from ryanteck.
Microsoft Trust UI Provider - Certificate Trust Link -
468.93 kB -
02/02/2016 at 10:14
Download
