I now have a working cross-compiler and a C runtime environment and libc based on gcc 4.9.2 and newlib 1.18.0 with floating point emulation. I have created a linker script for the T030 along with some startup code and the first prototype of my own C based ROM monitor is now ready:
T030 ROM BIOS v1.00 ------------------- Checking RAM: 512 KB OK #> h d - Dump address: d h - Help g - Run: g r - Dump registers u - Run in user mode: u w - Write single byte: w x - Transfer file with XMODEM: x #> x 90000 Starting XMODEM receive... CCC Done, bytes received: 36992, write errors: 0 #> g 90000 T030 TEST MONITOR v0.02 ----------------------- *> r SR: 2100 SSP: 000fffa0 USP: fffffffe VBR: 00080000 CACR: 00000000 *> g 000000 Exception #4 (illegal instruction) SR: 2104 PC: 00000000
A simple interrupt routine to use one of the MFP timers to blink a led can be written like this:
void __attribute__ ((interrupt)) timerb_isr()
static uint8_t c;
if (c++ >= 50)
if (bit_is_clear(MFPGPDR, 0))
bit_set(MFPGPDR, 0);
else
bit_clear(MFPGPDR, 0);
c = 0;
void enable_led()
MFPTBCR = 0;
MFPTBDR = 255;
// enable interrupt for timer B
bit_set(MFPIERA, 0);
bit_set(MFPIMRA, 0);
set_vector(72, timerb_isr);
// start timer B
MFPTBCR = 7;
I have also updated the glue logic in the CPLD so the CPU now runs at the full speed, a whopping 25 Mhz.
