1Step 1
Obtain the parts needed. Look at the parts list and look at what you have in your toolbox. You could also use an arduino or a teensy LC for this project easily if you wanted.
2Step 2
Assemble the box (I used 120mm in length and 107mm for the pieces - more specs to follow on box layout) and let it glue together with clamps
Matthew Carlson
