I love sub-projects. Some people start a lot of projects totally divorced from each other. I like projects that are building towards a greater goal. They have added purpose, makes them feel more important, I guess.
For example, I really enjoyed making the bearings that turned out to work really well. Seems other people did, too. Now I'm wondering if there's opportunity there for my first kickstarter - money would be used to make an injection mold for higher quality mass production and contributors would get bearings at a discount for their projects.
As the arm is coming together I can see that I'm going to need a gearbox to get enough power from my stepper motors to lift at the shoulder. I've been in love with the idea of hypocycloidal gears for a long-ass time now.
I'm filming Matthew (a Solidworks master) back in 2012. I was originally inspired by this other guy:
Who's website I found here: http://www.zincland.com/hypocycloid/
This morning I decided to download zincland's python scripts and see if I could generate some of these profiles. Save File > My Documents > Design - oh, there's already a folder for gearboxes? Hey! There's a folder for hypocycloids, too...and the files I'm trying to save are already here! But then what's this HTML file?
Turns out in Two thousand and eleven I had started creating a Javascript version of the DXF generator and then completely forgotten it.
So here it is for you: https://www.marginallyclever.com/other/hypocycloid-generator.html
No need to install or run anything. Just change your parameters and then save the DXF file contents (in the textarea) to a file of your choice.
If that's helpful to you, let me know and share with your friends.
Dan Royer
