SketchUp3D
10/11/2018 at 00:01 • 0 commentsDrawing of a water storage container connected to raised bed with drip line.
SMOKE ON THE WATER v0.2
10/08/2018 at 07:53 • 0 commentsAttempted a second time to get the correct BPM. I would like to also point out this demonstrates that you may have multiple valves that lead to more garden beds.
SMOKE ON THE WATER
10/07/2018 at 19:23 • 0 commentsThe "Smoke on the Water" intro beat has always been a go-to song since I was young.
When trying to expand on my project, I wanted to use multiple valves so that I could water more garden beds. But when playing with the four valves, I thought it was only timing that I need to make the beat. I must admit I have no natural ability to keep a beat or have any rhythm, so I am proud of what I learned about music. Tabs on guitar are awesome and I hope I can build my skills. If it wasn't for the musical instrument challenge I wouldn't know about tabs on a guitar or BPM.
APP
09/01/2018 at 21:58 • 0 commentsThis app was created for my own use, but Blynk can still be used. My app has an on and off remote push buttons, and an automation switch that is connected to a moisture sensor. One may set the threshold to water plants desired moisture level.
Box for Components
07/06/2018 at 17:08 • 0 comments
The file titled NyBox.cdr is a CorelDraw file that you can use to laser cut a box identical to the one pictured above. I use the box to hold all my components. -
System installed May 25 2018
06/03/2018 at 01:39 • 0 comments -
REAL TIME CLOCK
05/20/2018 at 01:08 • 0 commentsFound out that It may be beneficial to have a RTC. Found out that microelectronics can put into a deep sleep mode and wake them up when you need them to do something. I will be activating the device between 5:00 to 6:00am/\pm to take moisture reading and decided if the garden bed needs to be watered. Furthermore having the device only awake for a few hours per day a save energy on my 12v battery powering the device.
