ugly&boring version of a 3d-printable case for the whole assembly :-P
after moving components around a bit, and adding a 1200mAh battery...
the current bounding-box measures: 104mm x 46mm x 17mm
(this *will* change, since currently the various components on the pcbs are not factored in)
