and another minor mistake...
A project log for PiBoy-Zero
yet another portable console! ;-) roughly the size of a gameboy micro, with a 2.2" display
johschneiderJohSchneider • 04/02/2016 at 14:25•2 Comments
another wrong footprint...the push buttons used for start/select group their four pins in pairs - the other way round
... really need to learn to double check the datasheet for all components that have more than two leads - even trivial ones like buttons :-P
oh well - the fix was to desolder the button, cut some traces and amputate a leg >:-)
updated the pcb layout and pushed the changes to git and osh-park
update 2016-04-13
for anyone who happen to have this buggy version, the fix looks like this:
cut the start/select traces at the red lines, and do not solder the button pads marked with the circle...
arnaud.durand wrote 04/04/2016 at 19:27 • point
Is it safe to order the PCB now? I can't wait :-D
JohSchneider wrote 04/07/2016 at 18:56 • point
the separate components seem to work fine (buttons, display, power, ...) but i have not tested the system as a whole yet... still in the process of putting the software together and hope not to run into another HW bug :-P
if you feel daring go for it and order, or wait a bit longer till i have everything up and running :-)
