Enclosure model (Varisom).PDFThe latest custom made enclosure prototype 3D model (created by Varisom.com)Adobe Portable Document Format - 145.91 kB - 07/24/2016 at 14:49 |
EEZ PSU ILI9341 display test.zipArduino sketch for testing TFT320QVT 3.2" touch screen. UTFT lib is required and UTFT.cpp modification.x-zip - 9.49 kB - 05/26/2016 at 13:27 |
EEZ PSU W5500 examples.zipArduino sketches that can be used to test W5500 Ethernet communication on Arduino Shield r2B6b or later.x-zip - 10.69 kB - 05/25/2016 at 11:24 |
CVR-Special -EEZ PSU rev2.PDF3D model of customized enclosure (280x80x240 mm)Adobe Portable Document Format - 717.11 kB - 05/02/2016 at 08:53 |
EEZ_PSU_sim_setup.zipSoftware simulator for the EEZ bench power supply firmware. Could be used to test all supported functionality without underlying hardware.x-zip - 2.10 MB - 02/03/2016 at 22:06 |
EEZ PSU SCPI reference guide.pdfThis manual contains reference information for programming open hardware/open source EEZ bench power supply over the remote interface using the SCPI programming language. It's covers functionality of firmaware version M1 (Milestone One).download - 3.20 MB - 02/03/2016 at 22:01 |
Denis
