Project completed !
04/02/2016 at 17:16 • 0 commentsI received my new "bottom" case. Except a small problem with the micro card slot (1mm little too smal). Everything‘s perfect.
I changed the bottom case and everything works fine.
3d bottom case fixed !
03/23/2016 at 06:58 • 0 commentsI just find out the problem with the bottom case longer than the top case !
It was not a openscad render error (as I thought naively at first) but I imported the 4 buttons version of the Adafruit case for the bottom (and not for the top) which is longer than the 2 button version !
I’ve changed the import directive in bottom.scad file, fix elements position and all seems right.
I’m thinking to add a support for the screen (because screws are not holding very well in plastic) and send it back to print again.
Remapping keys
03/20/2016 at 11:04 • 0 commentsI’ve found a good key combination to work in many games including Neo Geo.
Here’s the PiTFT mapping :
- (5) TAB : Insert coin for Neo Geo games
- (6) ENTER : Start
- (12) SPACE : Select
- (13) X : X
- (16) Y : Y
You’ll find my Adafruit-Retrogame version here : https://github.com/paulgreg/Adafruit-Retrogame/tree/2buttons
3d update
03/20/2016 at 10:55 • 0 commentsI printed all buttons in ninjaflex using https://www.3dhubs.com/.
I’ve made top piece 4 mm longer to fit bottom.
I’ve also change micro sd hole in bottom part to expose less Pi part.I’ll soon send them to print using 3dhubs.
3d case received but with a length problem...
03/12/2016 at 11:40 • 0 commentsI’ve got my 3d case printed from sculpteo but openscad messed with bottom case’s length : https://twitter.com/paulgreg/status/708617332520833024
Case sent to print to sculpteo
03/08/2016 at 07:42 • 0 commentsI’ve just send my design to sculpteo, a 3d printing service.
See my gallery here : http://www.sculpteo.com/fr/gallery/public/paulgreg/
Audio circuit soldered
03/06/2016 at 11:22 • 0 commentsI’ve just soldered audio circuit and used jumper pin connector to connect it all.
It works great. Sound quality is very good.
Audio’s working
03/05/2016 at 17:21 • 0 commentsGot audio working following Adafruit tutorial https://learn.adafruit.com/adding-basic-audio-ouput-to-raspberry-pi-zero/pi-zero-pwm-audio
Pi Zero & Adafruit components have arrived
03/04/2016 at 23:18 • 0 commentsI’ve got my Pi Zero and first batch from Adafruit including a 2.4 PiTFT.
Screen works great.
Buttons printed !
02/13/2016 at 19:46 • 0 commentsI just got buttons printed by http://www.sculpteo.com/ (see pictures in project).
They are nice and solid.
