1Step 1
Gather all the components
2Step 2
Use Dremel tool to drill holes for DB9 sockets. It's very easy in soft and thin plastic.
3Step 3
Solder wires. For me the easiest way was to solder to Arduino board first and then to cable socket. When you are done, connect and test joystick #1
4Step 4
Complete the job.
5Step 5
Secure USB cable with knots. Add some glue and also seal the cover with glue.
Finished adapter top
and bottom
