Inspired by http://www.thingiverse.com/thing:464463, this doodad transforms a 2L pop bottle and a smaller 300mL to 500mL bottle into a solar water distillery. The smaller bottle is screwed directly into the doodad. The 2L bottle is cut latitudinal. The moisture containing material is placed in the bottom section. The doodad with bottle attached is placed in the bottom section. The top section is placed over top the doodad and the entire apparatus is placed in the sun for the distillation to commence.
Look to the thingiverse page for an STL ot print your own.
ken.do
Still looking for help with customization scripts!!
Will print in the morning!
It is getting bigger... not what I had in mind initially, but I guess we have to go with what works.
What if you tried a can in the middle instead? Shades the water from the sun then.
