Brainless & Disposable Bench Power Supply
Build a bench power supply with as little brain power needed
Build a variable power supply as cheaply as possible using an ATX power supply and off the shelf step-up/step-down transformers and an ATX breakout board. Boards are affixed to ATX PSU metal casing via motherboard standoffs after drilling holes.
  • 1 × http://www.amazon.com/DROK-Numerical-Switching-Adjustable-Stabilizers/dp/B00BYTEHQO DC-DC Buck Converter Step-Down Power Module
  • 1 × http://www.amazon.com/DROK-Converter-Transformer-Motorcycle-Automotive/dp/B00DWX8PM2 DC-DC Boost Converter Step-Up Power Module
  • 1 × http://www.amazon.com/Rockminer-Breakout-Board-ATX-Adapter/dp/B00V44UNXU ATX Breakout Board
  • 1 × Any ATX computer power supply lying around
  • 1 × http://www.amazon.com/Rosiness-M3-Stand-off-Accessories-Assortment/dp/B00LGBM3J8 Nylon standoffs
View project log
  • 1
    Step 1
    Connect power supply ATX cable to ATX breakout board
  • 2
    Step 2
    Connect a terminal block on the ATX breakout board with 2 wires to the buck module IN terminal block
  • 3
    Step 3
    Connect a terminal block on the ATX breakout board with 2 wires to the boost module IN terminal block
View all 6 instructions
