Build a bench power supply with as little brain power needed
Also found the following for pretty cheap:
Connect power supply ATX cable to ATX breakout board
Connect a terminal block on the ATX breakout board with 2 wires to the buck module IN terminal block
Connect a terminal block on the ATX breakout board with 2 wires to the boost module IN terminal block
