Fixed the code not displaying unicode strings correctly in python 2.7, at least for the weather-module. In this case, the fix was to use the line
from __future__ import unicode_literals
at the beginning near the rest of the imports. This tells python to use unicode as the default encoding scheme for the strings in the file. If not used, the icon text is rendered as a bunch of "icon not found" boxes.
