Thanks Adafruit
06/06/2016 at 18:16 • 0 commentsAfter posting on their forum, they promptly got back to me to let me know how to reset and print a test page.
Plug in power and hold feed button at the same time
Printer works fine now.
After months of working just fine..
05/23/2016 at 23:21 • 0 commentsThermal printer has seemed to have given up on life, and doesnt really feed or print anymore, sent a message to adafruit to see if there is anything about it that is serviceable.. luckily 30$ for a knew one isnt too bad.
5 steps forward 8 steps back.
05/23/2016 at 23:00 • 0 commentsI got all my own code up and running on the new 64gb sd.
My weather api is failing and I haven't tracked the issue yet.
I installed Jasper and now am trying to satisfy all the dependencies.
Stuck with trying to get openfst and phonetisaurus....
Moving Forward
05/18/2016 at 00:07 • 0 commentsMonday May 16th-17th
Jasper install was a fail due to lack of space, ordered new 64gig SDcard to my surprise, when dd'ing the original 8gig to the new card, i found i couldnt expand the file system. One full day later i gave up and started from scratch, is moving quickly and i am updating the instructions and this "blog" as a whole. lesson learned, if you have a permanent or semi-permanent project dont use the NOOBS install, you cannot expand the file system later.
Progress...
05/09/2016 at 23:21 • 0 commentsMonday May 9th
Installed Jasper, via the install script found here https://howchoo.com/g/yti5mmq0ntu/add-voice-controls-to-your-raspberry-pi-using-jasper
Lettin ya know what i done did..
03/08/2016 at 06:41 • 0 commentsMonday March 7th 2016
Installed a USB Microphone
Installed PiAUISuite - requiring work to make it work, havent given up yet.
Have added more functionality including the ability to print the current song, artist, and album via the thermal printer
