The helicopter traditional designs use a main rotor to generate lift and displacement, and a tail rotor for counteracting the torque applied to the fuselage. Another design known as the coaxial rotors, helicopter uses a pair of rotors mounted one above the other to give support and displacement.
To counteract the torque, the rotors rotate in opposite directions, creating equal and opposite torques which cancel and eliminate the need for a tail rotor. The yaw control is achieved by increasing the collective pitch of rotor collective pitch and decreasing the other. coaxial rotors also reduces the effect of lift asymmetry because as they rotate in opposite directions, the two sides of the rotor disc have a retreating blade and a moving blade. My project iclinaçao the lower upper thane helices are fixed (constant) the direction control is unique rear engine.
Another advantage of the coaxial rotor design is a greater burden for the same power output. As a tail rotor consumes some available energy produced by the engine, with the coaxial rotor design the extra energy is available to lift more load. Furthermore, eliminating the tail rotor reduces the noise, allows a more compact design, and increases safety on the ground.
The main disadvantage of coaxial rotor design is increased mechanical complexity of the rotor system. Two oscillating rotor heads and their control rods for both rotor systems have to be built on the same mast, and which in itself is more complex because of the need to rotate the two rotors in opposite directions.
However, this is partly offset by the elimination of the complexity of the tail rotor system. Despite the increasing complexity of the rotor system give rise to an increased risk of a catastrophic failure, helicopters with this type of design has a good track record of reliability.
Jose Pedro R. A. Ribeiro
danfer adrian
Lucas Tarraf Vaz
Investidores e profissionais são bem-vindos para se juntar a nós no projeto coaxial Helicopters elétrico, para nos ajudar a alcançar nossos objetivos de produção em grande escala. Existem algumas regras rígidas que devem ser observadas quando recebemos ofertas de potenciais investidores, por favor leia as informações cuidadosamente para decidir se investir ou fazer( contribuição doação )
1. Procure aconselhamento profissional independente.
Investimento considerados de alto risco. Faça consulta independente e procure antes de tomar uma decisão de investimento.
2. Plano de Negócios.
Uma cópia do Plano de Negócios do projeto sera revisto e estará disponível mediante investimento ,contribuição .
3. objetivos
a. avançar o projeto para a fase de pré-produção.
b. Reestruturação do grupo ,com mais técnicos
c. Continuar o projeto compatível com os fundos disponíveis.
d. Promover o desenvolvimento do sistema de voo .
e. Promover o desenvolvimento de motores elétricos de potencia de desenho inovador
O objetivo a curto prazo do grupo é levantar R$20000000,00 vinte milhões de reais .
4. Pacote Mínimo.
Apenas um número limitado de parcelas de investimento estarao disponíveis esse ano.
