Here's what it works like:
I started by soldering wire wrap wire to the photo resistors, then shrink wrapping the ends to prevent shorting.
![](https://cdn.hackaday.io/images/1475261534366448662.jpg)
Then I inserted a photo resistor into the hole in the last page of the book.
![](https://cdn.hackaday.io/images/6239991534366508336.jpg)
Metal duct tape was used to secure the photo resistor in place (the sticky side of the tape does not conduct).
![](https://cdn.hackaday.io/images/2024611534366582547.jpg)
This was repeated for the five active holes.
![](https://cdn.hackaday.io/images/5340091534366620152.jpg)
It looks like this from the front side.
![](https://cdn.hackaday.io/images/1791661534366660093.jpg)
Using the schematic, the Arduino was connected to the Adafruit sound board.
![](https://cdn.hackaday.io/images/1909961534366704184.jpg)
![](https://cdn.hackaday.io/images/3063911534366731545.jpg)
The relay and more Arduino connections are made.
![](https://cdn.hackaday.io/images/9179281534366768508.jpg)
Wires from the photo resistors (the board book) are attached.
![](https://cdn.hackaday.io/images/5029491534366816158.jpg)
Using some sticky putty, the board book was attached to the case (I didn't want things too firmly attached until I have tested the book more completely).
![](https://cdn.hackaday.io/images/8619511534366926436.jpg)
The Arduino sketch for this is included in the files on this site.
