Hackaday.io Hackaday.io
Sign up Log in
The Fever Tracker
Uses a PiZero,Thermo sensor,Neopixel Ring and AdafruitIO to sense & report fever status so kids can stay home from school & build more gear.
mrdiealotMrDieALot
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
484 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
577
2
484
3
Team (1)
  • mrdiealotMrDieALot
Join this project's team
ongoing project
raspberry pi Neopixel wifi temperature sensor medical adafruitio
This project is submitted for
  • Adafruit Pi Zero Contest
This project was created on 02/16/2016 and last updated 10 years ago.
Description
When you wake up with a fever, real or imaginary, and want to stay home from school you can use this device to easily show your parents you are really sick. The Neopixel ring will show colors to show how much of a fever you have. Reder is hotter bluer is colder. The numbers will also be reported to AdafruitIO so your parents can see online that you are not faking it during the day.
Components
  • 1 × PiZero https://www.adafruit.com/products/2885
  • 1 × Miniature WiFi (802.11b/g/n) Module https://www.adafruit.com/products/814
  • 1 × Lithium Ion Polymer Battery - 3.7v 1200mAh https://www.adafruit.com/products/258
  • 1 × PowerBoost 1000 Charger - Rechargeable 5V Lipo USB Boost @ 1A https://www.adafruit.com/products/2465
  • 1 × NeoPixel Ring - 12 x WS2812 5050 RGB LED with Integrated Drivers https://www.adafruit.com/products/1643
View all 7 components
Project Logs
Collapse
  • Fever Tracker on Adafruit Show And Tell
    MrDieALot • 02/25/2016 at 03:03 • 0 comments
    Progress on Fever Track shown off at this weeks Adafruit Show And Tell.
  • Prototype
    MrDieALot • 02/24/2016 at 03:30 • 0 comments
    Set up Pi
    Wired up sensor on board
    Connected to pi
    Used code from Learn pagehttps://learn.adafruit.com/adafruits-raspberry-pi-lesson-11-ds18b20-temperature-sensing/
    Ran python, got data.
    Prototype works.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Die, Master Monkey! wrote 03/01/2016 at 02:05 • point
A really cool idea! So much for the old "I don't feel well" strategy. :)
tomwsmf wrote 02/16/2016 at 07:40 • point
Sensor idea for you.... https://www.adafruit.com/product/381
Code and examples in python here...
https://learn.adafruit.com/adafruits-raspberry-pi-lesson-11-ds18b20-temperature-sensing?view=all
Time to crack open the Python book I got you:)-
Extremely useful and adjustable sensor which have several advantages including high reliability, long lifespan
Project Owner Contributor
DIY simple Capacitive Proximity sensor
mircemkmircemk
I am building an automated aquarium controller to fit into my home automation system.
Aquarium controller / home automation
pjpj
This simple, self-made device effectively identifies magnet polarities, even for complex shapes
DIY Magnet Polarity Detector - Sensor from PC fan
mircemkmircemk
Add SI1133 Lux and UV sensor to SensorWatch, a Casio F91W drop-in replacement
SensorWatch UV Sensor
wesley-ellisWesley Ellis
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "The Fever Tracker", please tell us the reason.
Send message
Remove Member
