1/2" nylon ball-bearing that I drilled and tapped a 6-32 thread into 3/8" deep.
These ball-bearings came from a wonderful place. Here is the link to the site.
http://myworld.ebay.ca/toolsupply/
This nylon plug made an excellent holder and allowed the drill hole to be centred.
With a round chainsaw file I cut a grove into the nylon ball. Then using J-B weld and the 6-32 screw I attached the ball-bearing to the Fibreglass shafts. The spring mounts were attached by 4- 4-40 set screws 1/2" in length. The set screws touch, this locked them in place.
The end effector socket mounted.
The elbow joint mounted.
