Step 3 : Catkin workspace and tutorials
05/09/2016 at 07:50 • 0 comments...
Step 1 : Fresh install of Raspbian
02/29/2016 at 10:20 • 1 commentThe creation of a new robot start by setting up the needed tools.
In this step we will install a fresh Raspbian OS (from windows OS).
If you already have a SD card with Raspbian, you can go to Step 2.
1 - Download Raspbian
Download Raspbian :
https://www.raspberrypi.org/downloads/raspbian/
Click on the "Download ZIP" button of the Full desktop image.
Extract the image file from the archive.
2 - Format the SD card
Download SD Formatter 4.0 :
https://www.sdcard.org/downloads/formatter_4/
Install it.
Insert your SD card on the computer
In SD Formatter 4.0,
- select your SD card,
- in option, set FORMAT SIZE ADJUSTMENT to ON,
- click format.
3 - Write the Raspbian OS on the SD card
Download Win32DiskImager :
https://sourceforge.net/projects/win32diskimager/
Install it.
In Win32 Disk Imager
- select the Raspbian image file downloaded earlier,
- select the right device,
- click "Write" button and wait,
- eject the sd card.
