Testing the setup
02/17/2016 at 01:43 • 0 commentsThis is the test run we took part way through
Removed Battery
02/17/2016 at 01:42 • 0 commentsAfter some time on forced fed AC power the battery gave up and force shutdown the unit, we removed the battery to compensate
Hacked AC Power
02/17/2016 at 01:41 • 0 commentsWe hacked AC power direct to the board due to a dodgy connection in the socket
Additional Gallery
02/17/2016 at 01:39 • 0 commentsCornflake arcade proto
Some additional pictures I couldn't add to the gallery, wiring and finished product
