1Step 1
Make sure your an SD Card breakout board which breaks out all 6 SDIO signals.
Then wire the signals to the corresponding pins on your hat's gpio header, keeping the wire length as short as possible.
SDIO Signal GPIO Pin # SD_CLK 15 SD_CMD 16 SD_DATA0 18 SD_DATA1 22 SD_DATA2 37 SD_DATA3 13 3v3 1 or 17 GND 6, 9, 14, 20, 25, 30, 34, or 39 I also placed a 10uF 16V Cap across the GND and 3v3 rails close to the card itself.
The card already includes 75 Ohm resistors on the data lines.
2Step 2
First make sure you have at least 1GB of free space on your MicroSD card (you may need to use raspi-config).
Then prepare the Pi for kernel module compilation:
# Update your RaPi sudo apt-get update && sudo apt-get -y upgrade # Install the Prerequisites for Module Compilation & Menuconfig sudo apt-get -y install bc rpi-update git libncurses5-dev -
3Step 3
Modify the boot config, update firmware and kernel, and reboot:
# Modify /boot/config.txt so the sdio dtoverlay is loaded on boot. sudo sed -i -e "/^dtoverlay.*sdio/d" /boot/config.txt sudo sh -c 'printf "dtoverlay=sdio,poll_once=off" >> /boot/config.txt' # Install the latest firmware and kernel sudo rpi-update # reboot sudo reboot -
4Step 4
Install rpi-source and run it to download the kernel sources:
cd ~ sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O /usr/bin/rpi-source && sudo chmod +x /usr/bin/rpi-source && /usr/bin/rpi-source -q --tag-update rpi-source --skip-gcc -
5Step 5
Until the mainline kernel driver works properly or Atmel's own driver actually compiles we need to pull the driver from upstream:
# avoid having to dl all of linux-next wget -r -l1 -e robots=off -nH --no-parent --cut-dirs=9 --reject="index.html" http://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/plain/drivers/staging/wilc1000 -
6Step 6
Now a quick change to one of the files. The driver will fail to compile:
nano +567 wilc1000/wilc_wfi_cfgoperations.cYou should see something like this:
cfg80211_disconnected(dev, pstrDisconnectNotifInfo->u16reason, pstrDisconnectNotifInfo->ie, pstrDisconnectNotifInfo->ie_len, false, GFP_KERNEL);Replace it with:cfg80211_disconnected(dev, pstrDisconnectNotifInfo->u16reason, pstrDisconnectNotifInfo->ie, pstrDisconnectNotifInfo->ie_len, GFP_KERNEL)
7Step 7
Add the driver source code to the kernel:
mv wilc1000 linux/drivers/staging && cd linux # edit the staging Kconfig sed -i -e "/^endif \# STAGING/d" drivers/staging/Kconfig printf 'source "drivers/staging/wilc1000/Kconfig"\n\nendif # STAGING' >> drivers/staging/Kconfig # edit the staging Makefile printf 'obj-$(CONFIG_WILC1000) += wilc1000/' >> drivers/staging/Makefile -
8Step 8
Update the kernel configuration:
make menuconfigNavigate to
Device Drivers ▸ Staging Drivers
Set Atmel WILC1000 SDIO (WiFi only) to M
9Step 9
Now for compilation:
# Run make prepare for good measure make prepare # Build the modules make SUBDIRS=drivers/staging/wilc1000 modules # If all goes well, install the modules sudo make SUBDIRS=drivers/staging/wilc1000 modules_install sudo depmod
10Step 10
Reboot and power cycle the card by removing it then reinserting it
sudo reboot
If you've made it this far, congrats! You should now be able to see 2 new devices when you run ifconfig: wlan0 and p2p0
jarocks
Hi,
I'm trying to follow your instruction, but at the step 4, I have a problem. The instruction "
rpi-source --skip-gcc" doesn't work : Makefile:595: include/config/auto.conf: No such file or directory
If you look at the file, there is no config folder. Where did it go ? Shouldn't it be here since I just unpack the files downloaded just before ?
