Hackaday.io Hackaday.io
Sign up Log in
RSSI mapper for muenchen.freifunk.net
I wanted a really mobile setup to measure the RSSI for our installations of muenchen.freifunk.net. It should be easy to carry and easy to us
filidfilid
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7 comments
26 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 4
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 7
View Gallery
276
7
26
11
Team (1)
  • filidfilid
Join this project's team
  • Linuxpinguin.de
completed project
ESP8266 Neopixel freifunk
Related lists
localization. Distance.
all project realted that topic
This project is submitted for
  • Adafruit Pi Zero Contest
This project was created on 02/21/2016 and last updated 10 years ago.
Description
I wanted a really mobile setup to measure the RSSI for our installations of muenchen.freifunk.net. It should be easy to carry and easy to use.
As long it did not find a muenchen.freifunk.net node, it does display the number of surrounding Wifi nodes. When it did find one or more muenchen.freifunk.net nodes, it selects the one with the current highest RSSI and displays this via the NeoPixel ring. For the next 60 seconds, this node is fixed. If it is lost, the search starts from the beginning.
If you add a serial console all the found SSIDs and more information is available with 9600-8-n-1.
Files
JPEG Image - 1.12 MB - 02/25/2016 at 08:27
Preview
JPEG Image - 743.50 kB - 02/25/2016 at 08:27
Preview
JPEG Image - 413.29 kB - 02/25/2016 at 08:27
Preview
JPEG Image - 405.46 kB - 02/25/2016 at 08:27
Preview
Components
  • 1 × Adafruit Huzzah ESP8266 Feather
  • 1 × Adafruit NeoPixel ring 16 LEDs
  • 1 × bunch of wires
  • 1 × LiPo battery 3.7V
Build Instructions
Collapse
  • 1
    Step 1
    See https://www.linuxpinguin.de/project/rssi-mapper-for-muenchen-freifunk-net/
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
filid wrote 05/24/2016 at 07:26 • point
I added a new project, which does GPS tracking and logging to a SD card.
https://www.linuxpinguin.de/project/wifiscanner/
filid wrote 02/27/2016 at 14:23 • point
I updated the source code to introduce a watchdog timer, which catches issues in the WiFi subsystem
filid wrote 02/25/2016 at 08:23 • point
Still working on this, but the ESP8266 boards don't have GPS and GPS draws a lot of power too. We currently do long exposure shots to build a heat map
PinheadBE wrote 02/25/2016 at 08:16 • point
Can't wait for more details...
PinheadBE wrote 02/25/2016 at 08:30 • point
Now you have my skull ;-)
Great work!
Elliot Williams wrote 02/22/2016 at 10:34 • point
This project is screaming out for a GPS module and some data storage.
Arduino based carburetor and throttle body balancer / synchronizer
Project Owner Contributor
CarbOnBal
dennisdennis
3 Day & Current Weather with ESP32 T-Display and openweathermap.org API
Weather Forecast with Lilygo T-Display ESP32
johnsonfarmsusJohnsonFarms.us
The 2016 Hackaday Prize
A stylish desktop widget shows you the actual foreign exchange rates and the time of different locations
ForEx display
stefanStefan
A MAX7219 driven Display, controlled by an ESP8266 SoC and MQTT
ESP8266 MAX7219 Dot Matrix Display as MQTT Client
ninharpninharp
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "RSSI mapper for muenchen.freifunk.net", please tell us the reason.
Send message
Remove Member
