The picture on the main page is the second prototype. It shows the tubes I use for calibration of the sensors. I have to calibrate the sensors because they don't all give exactly the same readings out of the box. The tubes are used to tie them all together and apply the same vacuum pressure. The software then stores calibration values and uses them to calibrate the display.
The "vacuum pressure" in this case is just me sucking hard... If you have more sophisticated hardware I suggest you use that! The calibration routines have been overhauled and are now much more accurate.
Features:
- Balance up to four carbs / throttle bodies (2-4 user selectable).
- digital RPM guage.
- Absolue (bar graphs) or relative (centered around the master carb's values) display.
- Calibration for accurate results, calibration info downloadable to PC.
- Saves settings so you don't need to set it up every time you use it.
- User selectable master carb.
- Display brightness and contrast via software, no old fashoined potmeters required.
- Uses cheap and robust parts.
- Very low parts count, easy build.
- cheaper than most solutions.
Ok, lengths of aquarium hose could be cheaper but a PITA to use (IMHO).
- software tweakable to the max, even by non programmers
- User friendly menu system.
- Freeze display feature to make it easier to read numbers and bar graphs.
- Real time data logging to PC via USB (Serial) so you can look at the vacuum pulses for yourself.
The display is wired up the old fashioned way in the newest CarbOnBal "Basic" prototype. The Arduino has enough pins and I would not know what to do with more pins anyway.
If you want to build this but need help just drop me a line. I'll do what I can to help you get your own version built. Also if you need help with the software or have tips on improving it, I'm all ears.
dennis
davedarko
Dimitar
Michael O'Brien
Abraham Limpo
Hi and thank you for this project - I already had everything in my project box except for the MAP sensors so this came in very handy during the setting up of the carbs on my 1983 GSX1100EZ. No problems with the build but I now fancy trying the laptop software and I can't seem to get this working. My device info shows Ver:2.0b2 and when I connect with ver 1.0 of the laptop software it connects and shows Dumping Sensor Data but the data is illegible. Trying ver 2.0 I can connect (without the message) and it gets settings data but I don't get any sensor data and the LCD screen reverts to the normal data screen - any advice?
Many thanks
David
